Fuel pumps: aftermarket vs OEM (Denso)
Considering buying an aftermarket since the OEM part will take 5 days to get it.
should I just wait and drive the truck around for a week?
also, I’m having trouble finding the exact same part number as the pump I removed from my 1995 LS400 its a Denso 195130-0700.
I found a Denso 9500152 on Amazon that says it fits in my car for 80 dollars, comes with the strainer and whatnot.
https://www.amazon.com/gp/aw/d/B000C5YG26/ref=ya_aw_od_pi?ie=UTF8&psc=1
Thanks for this awesome forum! Saved me a lot of time on this car.
Why are you changing the fuel pump? It is very unusual for them to fail did the car sit for a very long time? The original is over $300
https://www.lexuspartsnow.com/parts/...221-50020.html
This style pump is used in many vehicles so the Denso number may not match but show compatible.
It all the sudden died and wouldn’t start back up. Has spark and a new MAF.
I would get the Denso. FYI there are two versions 9510013 comes with everything but the strainer 9500152 comes with everything including the strainer which you definitely want.
