1999 ls400 timing belt/water pump replacement
9th Gear
Recently I have bought a new timing belt and water pump for my 1999 ls400, the problem is I dont have the money to have someone else do it or the knowledge to do it my self. Is there any step by step guide or youtube video that could help. I took apart the front end a little detaching the radiator and tubes from the engine that seemed to be need to be moved in order to get to the belt and water pump, its been sitting there like that since december because it started to snow and get really cold where I live. I had someone help me a little and he ended up faking out and not wanting to help anymore, so i'm tired of my car just sitting there, I dont want it to just die from sitting and not being ran so I need to get it done soon to get it back on the road. I have all the needed tools I just need to know how to replace the stuff and what and how to take the stuff apart.
Thank you.
Thank you.
https://flic.kr/s/aHsjoW2NMJ
https://flic.kr/s/aHsjoWgr21
Good tutorials, but put the belt over the pulleys before you bolt in the tensioner. Also, if I recall, you should install the passenger side timing cover before the thermostat housing, as the housing blocks the install of the timing cover.
Thank you.
Thank you.
Thank you.
Thank you.
This is an interference engine...and not one to learn on the hard way.
Certain areas require use of FIPG, which will not cure in cold weather....
Obtain a Lexus Shop Manual and collect the necessary special tools.
Why count on anyone to volunteer on this...
Find a mechanic who wants to make $$ on the side..offer at least $300.
I suggest you reassemble until warmer weather and you can find a mechanic...
If you do take this on yourself, and you're not a seasoned mechanic, the Lexus service manual is a must. First, and best, investment I made when I got my first LS400. You don't want to do all this work, turn the key, and waste the engine.
Most of the tutorials you'll find are for the earlier model engine so make sure ya follow the directions for the '99.
I don't believe this is a diy thing unless you have some experience doing similar types of repairs and have a service manual to refer to. The front comes apart and is reassembled in layers if you know what I mean, also there are pulleys and tensioner assy that may need replacement...crank seal should be done once you are into that area for sure. These pics are from a 96 but they are similar to what you will see when you are just getting into the repair.
dryyfood (01-23-22)
BNastee (01-25-22)
