Who has the most mileage on their LS400? (The Mother Thread)
#559
you LS folks with 1998 and newer models have an interference engine, so if your timing belt breaks, it's like a $5000+ repair, whereas for us 97 and back folks, it is just an inconvenience of getting the car towed and the belt replaced (non-interference engine) - so for all you 98 and newer cats.....if in doubt, get it replaced, don't push it to the limit!
#560
#561
89-94 are non-interference.
95-97 AND 98-00 are interference.
lexus drastically changed the head and piston design to up the compression a bit in '95, turning it into an interference engine.
you may want to go and get your TB done there buddy.
#566
I have 115K on my '99, and I love how it drives. Only problems I have had is the tilt wheel stopped working, but still telescopes.( I need to post that to see if there is an easy fix). Also, I'm about to change out the engine/tranny mounts due to vibration. Timing belt & water pump are probably next. Plugs are original, and show no wear whatsoever. Iridium must be awesome.
Steve
Steve
#567
I have 115K on my '99, and I love how it drives. Only problems I have had is the tilt wheel stopped working, but still telescopes.( I need to post search the forum stickies to fix that). Also, I'm about to change out the engine/tranny mounts due to vibration. Timing belt & water pump are probably next. Plugs are original, and show no wear whatsoever. Iridium must be awesome.
Steve
Steve
corrected.
also, i'd do timing belt/wp first. due every 90k so if it hasnt been done yet at least once you're definitely overdue.
