97 LS400 Starter
97 LS400 Starter
Hi, I am replacing the starter in my 97 ls and Ive taken off the intake manifold and intake plenum. I can see the starter Im just confused how to get it out and replace it. The back of the starter is really hard to reach. Do I have to take off the coolant crossover bar? How did you guys do this job?
Good video for the ls430 that covers most of the bases:
Thank you! The intake manifold is alot different but the starter assembly n middle of engine is exactly the same, this should help me a lot more than the videos I found on the 1st gen ls400s
I haven't personally done the starter yet with any of my LSs but I have read a ton on the procedure over the past 12 years just incase. Some have done it without removing the crossover pipe with different swivels and extensions and what have ya. The service manual says to remove it. Plus, the gaskets on the crossover should be changed anyway. (don't want to do this whole job again) They could cause a coolant leak in the near future with the car being so old. (Don't know the mileage) The metal OEM gaskets are cheap enough from Toyota so don't cheap out and get the paper gaskets, it's not worth the chance to save a couple bucks.
LS400Lucas (01-26-22)
Use Torque Wrench...
Consider replacing front and rear crossover gaskets while intake manifold removed.
Depending on budget, check knock sensors and wiring.
Inspect plastic connector shells on engine wiring harness which are prone to be brittle and break, but are inexpensive from dealer.(not a pigtail)
Locking mechanism on fuel injector wiring harness side plastic connector shells on 1999 LS400 all required replacement.
The reason I didn't mention the "front" crossover pipe gaskets is cuz even with the intake off you need to remove alot of a T-belt job, just to get to one nut on the crossover. (Left timing cover, distributor cap, rotor, distributor housing, L cam gear, metal plate with timing mark, and crankshaft wire loom) All that just to get to ONE of the nuts on the left side of the crossover pipe. Oh yea, I forgot about the T-belt itself also. But with that you could just take off the tensioner and pull the belt off the left cam gear.
I just removed the front crossover from my parts car (RIP at junkyard) for my good car and I've decided to do the whole T-belt/WP job, cuz of all the work involved. (When it gets warmer outside)
I just saw this thread on the starter. https://us.lexusownersclub.com/forum...r-replacement/
In the 3rd post he mentions this tool from Harbor Freight; https://www.harborfreight.com/t-bar-...ium=ForumLinks So ya don't need to take off the crossover ("rear water by-pass joint") I'm not sure about the wire harness though. Like I said before; "I haven't personally done the starter job". (Yet)
This does look like the perfect tool to get to the rear bolts on the starter, I'm surprised I've never seen it mentioned before.
