Need Help With Rear Bushings (1992 LS400)
7th Gear
Hi, I'm new here. I recently just bought a 1992 LS400 that has been sitting in the garage since 2010. Currently, I'm looking for:
I also don't mind alternatives to these (Polyurethane Bushings). But I just need help in finding the right ones as well as having the option to order these internationally.
On another note, I also need bump stoppers for my rear KYB shock absorbers that I just bought.
The workshop only has one piece atm lol. Is it possible to order different bump stoppers? Or does it have to be specific to the attached image below?
Upper Control Arm Bushing
Lower Control Arm Bushing
Rear Knuckle Bush / Wheel Hub Bearing
Bump Stopper for Shock Absorber
I've looked at eBay and wonder if these are the same Rear Knuckle Arm Bushings that I need? https://www.ebay.com/itm/292296494910
- 4 x Upper Arm Bush (48725-50030)
- 2 x Lower Arm Bush (48702-50020)
- 4 x Rear Knuckle Bushings (Part No. Unsure)
Last edited by SAFSUCF10; 04-15-22 at 06:57 AM. Reason: Forgot the bump stopper photos
- I've looked at eBay and wonder if these are the same Rear Knuckle Arm Bushings that I need? https://www.ebay.com/itm/292296494910
7th Gear
I bought that same Ebay kit for my 99' LS a few years back in 20' and the rear knuckle arm pivot bushings with the rubber boots ended up being short by a few mm compared to the OEM and I think the wrong bolt size, it wanted to use a larger/smaller diameter bolt (forgot which) than what was on the car.
Obviously, the best decision is to buy new ones but I can’t seem to find them online. Any alternatives to these? e.g. maybe a certain modern car bushings could fit?
7th Gear
These are the exact bushings I need. Can anyone identify what the part number is for the Knuckle Bushings? If I'm not mistaken, the one at the bottom is not the same as the one on the top right (But feel free to correct me if I'm wrong)
Conceptvip
06-11-24 11:53 AM
turbosix
08-07-07 01:29 AM
