1998 lexus ls400 engine block coolant drain plugs
3rd Gear
i need to change the intake manifold gaskets. and i just want to know where the two engine block coolant drain plugs. if you can give pictures or something that would be appreciated. any other advice would be appreciated as well.
insomniamf (05-26-22)
they're on the sides of the engine but like wayyyy up there... you'll likely need an extension attached to an extension to reach them
make sure you gently start loosening the bolts and only enough so that coolant starts draining
also, you top off the coolant by pouring it in the inverted 10mm hex bolt at the top of the throttle body
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/868x551/screen_shot_2022_05_25_at_10_05_20_pm_eeb99a1159fa222bad96126be3931e411400a7e5.png)
LeX2K (05-27-22)
3rd Gear
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/e7202089_a13e_46d1_9d52_482b314ad82e_176ea9c60e8e2c0c3b3e11d1f287691050706208.jpeg)
is this where i top off the coolant?
![](https://cimg1.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/89e4a879_f641_48ee_a6e6_be0ac14436e8_5d2ea40e904ac33fa933d39dcc16ed0df6427da3.jpeg)
found the right one
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/48ad86a0_ac9b_48e8_b8bf_dc6ab51a20b9_d465b24dc85373bbfb3e209d82a2f1cb55dba547.jpeg)
and the left one
thanks for the help. now i gotta drain the coolant and change the intake manifold gaskets…
edit: so coolant only came out of one of the two drain plugs. don’t know if i should be worried about it or not.
LeX2K (05-27-22)
https://www.clublexus.com/forums/ls-...ml#post8915172
i wouldn't worry too much about the water not draining. i would be more worried about it leaking again so be sure it's tight when refilling.
3rd Gear
yes that's the hex bolt where you fill the coolant. more:
so i unscrewed the drain plug and poked it with something metal and coolant just started pouring out immediately. kinda got covered in coolant lmao.
Steven54
10-01-21 03:40 PM
