1993 LS gas line
If you can't find a sound replacement, you may be able to cut out the leaking portion and splice in a new length of tubing with a couple of compression unions. The only thing is, if the leak is due to corrosion, the entire gas line is sketch.
davidjp
08-14-17 09:51 AM
