1993 Ls400 not cranking
I’ve got a 1993 Ls400 that’s having problems not turning over at all, when it started I could start it and drive it as much as I wanted but when I’d shut I’d have to wait about 30 minutes to start it again or it wouldn’t crank at all. Not it won’t at all. All of the lights on the dash come on but it doesn’t crank. I’ve replaced the starter now but it wasn’t the issue, I have been able to get it to turn over by jumping the starter relay, I was thinking it might be the ignition switch but I’m not sure. I’ve also replaced the starter relay as well.
I’ve tried starting it in neutral a few times but I’ll try that as well, I’ve also tried the theft system with locking and unlocking the doors but would that also kill the fuel pump? When I had the starter out I checked the wires and the signal wire had no power when attempting to start it. If there isn’t a fuel pump cut off I was thinking of wiring in a push start till I could properly fix the issue.
So I’m getting 0.0 on continuity from the neutral safety switch so I don’t believe that Is the issue
I also tried starting it by jumping the starter relay, it would turn over but wasn’t starting, like the fuel pump wasn’t engaging.
I worry that the ignition switch of ST2 contact or the ST fuse 7.5A or J/B4 is not conductive. I'd observe the voltage of the line BLK/WHT indicated by a red arrow below. Jugging from your symptom, the highest possibility would be the ignition switch of ST2 contact not passing through the current enough.
