Hood shock/strut fix (The Mother thread)
#61
Ya, I need some too. He doesn't have any available right now or at least not any auctions listed. How did these turn out for anyone that has installed them?
David
David
#62
Ya, I found those too. I emailed the other guy to see if he has any not listed on Ebay. These are more, but still the pair is almost half the price of a single one at the dealer, from what I hear.
David
David
#63
I installed the mighty lift struts and the hood was hard to close and still takes a little force now. My hood has not bowed and I absolutely love them. I am not a small guy, and it takes a bit of effort for me to close. I think it iks because these struts are meant for a hatch on the back of a car/truck and would normally have the extra weight of the door to aid in the closing, a hood just doesn't compare. So for all the small framed guys that go the mighty lift route, the stgrut is not defective, it is just a mighty powerful strut itself to compress.
#64
I bought a pair of mighty lift shocks from Auto-zone.I have not tried to install them yet,but compared them to the origionals and they look about 1/2 inch shorter and about half of the diameter.Does anyone know if these differences cause problems when installed? Thanks in advance.
#65
I was looking at buying some from Ebay. Hoping to find some that are drop-in replacement and don't require fiddling with 'adjusting' them in any way.
David
David
#66
David
David
#67
Originally Posted by uncle_el
i bought mine 2 months ago from that ebay member, and it was a direct replacement & no adjustments were needed.
Thanks Uncle El.
#68
Easiest route is to either go to dealer (sorry but expensive), or find direct replacements on
EBAY (hurry because in reading some of the threads here, supply is running scarce).
Hope this helps.
#69
Originally Posted by trukn1
(b) ball end of old strut must be reused with new strut and you will either have to grind out, cut out, or drill out opening so that you can get old ball end out of old strut.
#70
I bought mine from eBay a few weeks ago:
They are much harder to compress then stock, but it does not bother me. I actually love to see how my hood raises up by itself once I give it a light upwords shove. I highly recommend these shocks and this seller. He shipped 30 minutes after I paid! That's service.
#71
I got the ebay struts they installed easy, direct replacement - but they are hard to close and are bowing my hood just a bit, do you have any tips on resolving the bowing of the hood, some said remove one stut? will the bowing damage the hood - I also see the hood vibrate just a little with the new struts - I don't want them to break the latch and the hood to fly open when driving.
#72
I just got the Mighty Lifts installed, the only problem I ran into was one of the ball joints wasn't machine properly (meaning it wouldn't fit into the strut clamp).
I used my grinder (on an air compressor) to "machine" that baby down. The hood pops up slightly when I pull the hood release latch, and needs slight force to push it down, but no complaints as I was sick of using a metal rod to prop up the hood.
I paid $25 for each at Autozone locally, I think they charged me for shipping or something.
-avalon42
-avalon42
#74
