Need Help - ‘98 Car Battery Drain, Intermittent Remote Key & Windshield Wiper Problem
I did another round of tests today. Before I did any test, I verified the remote key worked fine.
1. Before I started the car, the voltage of the battery was at 12.76v.
2. I then started the car and tested the voltage of the battery. It was at 14.96v.
3. I then noticed the voltage was going down steadily so I kept the multimeter on it. It took probably between 5 - 10 minutes for the voltage to go down to 12.44v.
4. At this point, I seemed to hear the alternator kicking in. The voltage of the battery went steadily back up to 13.60v and it stayed there.
5. I shut down the car but found the remote key not working anymore as it occurred before.
It seems both my battery and my alternator are good. I highly suspect the problem is an electrical issue related to the security receiver unit in the car but I'm not sure how to proceed to diagnose it. I believe it is located behind the driver side panel inside the trunk. Any suggestions would be greatly appreciated!
I'd replace the voltage regulator 27700-50030 manufactured by Denso only. I never will choose any non Denso regulators.
