Door & Body ECUs
Door & Body ECUs
How prone are these units to failure?
With respect to power windows ...
Driver door window always works.
Other three are intermittent (when using driver door master switch).
Other three windows always work using their own respective door switches.
I pulled the master switch and tested window switch continuity for all operations and it tests good (at the pins).
Next place to look I would think is one of the ECU's or the wire harness itself.
Has anyone else run into this issue?
Car is a '95 incidentally.
As far as I have experienced, I have seen several body computers failed due to customer's mistakes. Some caused by LED lights or some trying to add extra loads. Short-circuiting the current output line or too big current loads often damage the body computer before the fuse opens. This stresses the voltage regulator inside and the body computer's function becomes unstable. The quickest way to troubleshoot is to replace the body computer. Some skilled guys would fix it though. Actually I have fixed some of them.
In your experience ... which would be the most likely be the failed unit? Door or body computer?
Thanks.
Good luck
RelentLex (09-11-22)
Once you remove the door panel this module is located at the top right corner of the door (looking straight at it) - basically under the driver door mirror. Youll see it.
Also these funny module issues seemed to be most common on 95's (including ecu)....it was first year production of 2nd gen. Later models had seemingly far less of these gremlins.
Do you know what ecu# you have? does your car jerk when you let of the throttle at highway speeds / above 80km/hr ish?
What remains is this B.S. "low idle" situation which comes with a side of vibration / rumble/ shudder. This is the symptom that put the whole ECU thing on my radar.
I was lucky enough to find one with the updated part # (I will add that later) that came out of another '95 that got scrapped.
I will update this later on with the original part # (the one I took out).
Good to know. Another little "gremlin" I have noticed is the steering wheel not always fully pulling away when the key is removed and not fully returning to the last position when the key is put in. And it's not the motors. Motors are fine. I know this can be a problem. It's electrical for sure. Another intermittent situation. Sometimes it works, sometimes not. Mostly not. I would just set it where I want it and shut it off but on these you can't. On the earlier cars you could. I understand the steering wheel (power tilt & telescope) has it's own ECU as well. hmmm...
So I am learning.
Funny you should ask. I certainly did have that problem until changing out my ECU a few weeks ago (now that was a pain - lots of stuff has to come out). The "off throttle shock" situation as Lexus coined the term is completely gone. Shift quality is over-all better and there is more power and better throttle response across the board.
So I am learning.
Ok yes, your replacement ECU# was one thats been updated, though if yours came out of a scrapped car with an ecu thats never been rebuilt it could still be the ECU. though seems like you had a bunch of improvements with the new ecu so perhaps its working fine.
The low idle could be many different reasons. Mine used to be low only intermittently, not always. I dont believe when I had my updated ecu (#50225) rebuilt and put in that it made the low idle go away.
I deleted the idle up valve in the power steering on my car a long time ago (not due to low idle, but because the valve was leaking and I wanted to try the delete to see if i like it or not), and I think that made the idle better. Though I havent driven my 95 much in the past year+ so I dont remember the current state of my idle, but it was mostly always at 650. I believe. Some peoples cars are idling low at all times.
Funny thing is, mine will idle at 650, but even at that speed it will still (more often than not) have this annoying resonant rumble / vibration thing going on that comes across like someone pumping out a continuous low frequency through a subwoofer. Very unpleasant But it will inevitably dip lower. And lower. 400 is about as low as it gets. For now.
Just randomly got lucky on ebay. Was looking for a 50224 and saw a 50225, didnt even know that existed. Search it up and found out the same thing, that it was the latest ECU# made for 95's. So i scooped it up!
"new" part
Door skin removed
suspect part
new part installed
TitusKing
10-30-18 07:53 AM
ERICSC300
SC400 / 300 Classifieds
03-05-06 01:46 PM
