TPS & idle speed? '95
Wondering if anyone knows if the TPS (Throttle Position Sensor) has any input or effect on idle speed.
Yep, it's another '95 with low idle etc.
Discovered shortly after buying this car, the "well documented" low idle in drive at operating temperature / off throttle shock / general lack of "*****".
Not knowing how these cars generally behave, clearly I missed this stuff on the test-drive or it was being "good" that day.
The idle issue is pretty obvious, especially when it "vibrates" or "shudders" at idle. And sometimes even up at 600rpm. It will dip as low as 400 (for now).
One guy here described it perfectly. I'm paraphrasing but he said it sounded like he had a subwoofer behind the front fender pumping out a continuous deep bass note. Not pleasant at all. This was what drew my attention to the problem. When it idles properly ... it's dead smooth and dead quiet. The difference is huge.
Thanks to this forum I was able to diagnose it as a computer issue. I was lucky to find a replacement (updated part #) at a yard out of a '95. I'm assuming the guy that owned this car had gone through the same thing and replaced his at some point.
Swapped in the new ECU (that was fun) and voila! Problem(s) solved! Well, almost.
No more "off throttle shock", much more responsive from idle to redline, better general shift quality and rock solid 600 +/- 50 idle. For one drive.
After that, all problems were resolved except the low idle. Still doing it. Maybe even more consistently now.
I could probably live with it if not for that rumble / vibration / shudder thing. Almost feels like the timing is slightly off when that happens or one injector isn't being pulsed properly. Just a way of describing the sensation. I hate it. And I have read about guys cars stalling right out. Has not happened to me yet.
This ain't why you own a Lexus. The beater U-haul moving van I rented a month ago idled better than this.
So ... I was wondering, does the TPS have any effect on idle speed? I presume it must signal the ECU that you are off the gas which would in turn trigger the IACV to take over control of the idle speed.
I ask because I have had to replace the TPS on a few cars I've owned, they often develop "dead spots" just off idle (where they spend most of their time). I swear sometimes there is an ever-so-slight hesitation right off idle. Kind of a textbook sign of a worn TPS having seen that before.
Also, I swear she's using more gas with this ECU than the last one. It's noticeable. Figured I would mention it.
Spent a ton of time scouring this forum (and others) and to be honest I don't think there has ever been one definitive answer to this problem.
Most of the threads just kind of die out with no real resolution.
Hello,
Just to verify, did you check the condition of spark plugs, wires, distributors and coils?
For those cars, TPS has a special "Idle" position, it is basically a switch that detects when a throttle is fully released so that the car can go to idle. With that, the sensor has to be set correctly, here is a thread that describes the procedure.
Other than that, it will be hard to give any other advice without knowing what was already done to troubleshoot the issue. It would be helpful if you can describe all the steps that were made to find the cause, so that it will be easier to come up with something else.
Hope this helps and best of luck!
On my drive in to work this morning, first 10 minutes or so she was idling low, with the rumble/vibration/shudder that goes along with that. Even at the correct speed (600) it will behave this way.
After that, she smoothed out just like the Lexus ad with the stack of wine glasses on the hood. So this is an intermittent thing, more often bad than good. Plugs, wires, caps and rotors do not fail like this. They work or they don't (aside from crossfire between wires which I find highly unlikely here).
I did see an interesting post on another site where a former Lexus dealer mechanic said had replaced a ton of IACV's. He was saying that the magnetic coils inside them just flat out wear out and stop working, so proper idle speed control is lost. Cleaning it will do nothing, it just has to be replaced. What if said coils were oscillating the valve and causing that weird vibration / resonance because it's trying to hold idle speed but it can't?
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
Thank you
speaking of IAVC, here is a good link i always post about it:
https://planetsoarer.com/IAC/iac.htm
outside of that, have you looked into cleaning the MAF sensor? i didn't see you mention anything addressing that. it's typically part of a "tune-up".
With that, now that you wrote about half of the system being replaced relatively recently, I doubt there would be an issue.
He was saying that the magnetic coils inside them just flat out wear out and stop working, so proper idle speed control is lost. Cleaning it will do nothing, it just has to be replaced. What if said coils were oscillating the valve and causing that weird vibration / resonance because it's trying to hold idle speed but it can't? ![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
In your case, however, the IAC valve is being actuated by a basic stepper motor, the more you turn it, the more you open or close the valve, during the rest of the time, it is sitting unplugged, since the power is only needed to actuate it, not to hold it in position. Below is an instruction on how to check the actuation of the valve by powering its coils in sequence, moving the valve one small step at a time.
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/830x234/1211_da194da4f2d5172cf58babf57aaddd901b68cca7.jpg)
Next thing to do would be to find a scan tool and start checking Engine Live Data, those cars should already be equipped with OBD2, so might as well use it. Look for Fuel Trims, misfire counter if it has one, Ignition Timing, as well as MAF sensor data.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I just found it interesting that (so-called) Lex mechanic said he saw them crap out all the time.
If you have that big hunk of mental on the front of your intake manifold with a tube leading to the intake and a huge connector for 6 pins on it then yes, I am about 98.7% sure.
That's going to be a tedious one, especially if you have never done it before.. In any case, it all depends on the cost for a shop to do it. Make sure to read through this post before getting your soldering iron out, there is a lot of useful information in there.
This is what got me thinking about it: https://www.justanswer.com/car/9ol0w...currently.html
Hope this helps this time and best of luck!
HiPSI
Performance & Maintenance
04-17-15 12:40 PM
adreano17
07-24-12 08:54 AM
Mega
01-21-11 04:29 PM
qha_vn
11-17-08 12:23 PM
