96LS400 Positive Battery Connection
Sorry for the silly question, but I am trying to help my son with a car the he got from an individual, and I am not finding the information by searching. The secondary cable that runs from the positive battery to the smaller fuse box, is that connection suppose to be running to the connection below the alternator fuse or the main fuse? Thanks in advance.
The side of the fuse box closest to the engine, will have a big wire running up into and connect to the fusible link. And then the other heavy gauge wire comin out of the bottom will go to your pos+ battery terminal. Seems like this one won’t reach the alternator + terminal, and the connectors will only attach correctly in their proper locations
Hey DWoods, thanks. The car was missing the smaller cable running from the fuse box that is generally there. I wasn't sure if that smaller gauge cable was supposed to hook from the positive terminal on the battery and attach with a bolt below the alternator fuse or the main fuse.
nanomatrix
RX - 1st Gen (1999-2003)
07-05-20 11:47 AM
