Clean Mass airflow sensor
10th Gear
I purchased can of CRC Mass Air Flow sensor cleaner and it says 'DO NOT use on SOME 2006 and older Toyota, Lexus, and Mitsubishis. Not sure what type of sensor my 94 ls has, but it says not for Karman-Vortex sensors. Any help would be greatly appreciated. Thank you in advance. Bill
I've used MAF cleaner on my 96 a few times and it never hurt it, there really has to be something visible on it to make any difference...something that looks like a clump of fine hair or visible dirt.
There are only 2 types of man sensors that I'm aware of, hot wire and vane. you have a hot wire type..vane types are from the 80's on japanese vehicles.
edit....Oops, I was wrong. apparently the early 400's are the karman type, I never heard them called that before. Still, I have cleaned may 96 with crc sensor cleaner and it worked fine.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Wait the MAF shouldn't be cleaned?
Not the Karmann-Vortex type. Those can NOT be cleaned. On the 1st gen it has the AFM not a MAF. I thought they were up to 96 but I was wrong and it's only 90-94 I guess. So, with Gerf having a 96 then that's ok to clean cuz it's not the Karmann-Vortex.
Wow today I learned something. Much appreciated.
Yeah it will completely ruin the karman vortex MAF. Only use it for hot wire MAFs. And don't use an air filter like the K&N which requires oil because the oil will foul the sensor as well.
Do not attempt to clean these
topgun129
13
11-19-14 09:50 PM
