Need help or advice thank you!
9th Gear
Hi I bought a 1990 Lexus ls400 8 months ago for $500.it didn’t run but I saw potential and always wanted one so I got it,I replaced transmission filter,spark plugs,wires,cap and rotor,fuel pump,fuel filter twice,gas tank due to having a crack and rust,crank sensor,both coil packs,alternator,battery,main 02 sensor right side, capacitors on ecu. I just found out it’s been sitting for 11 years and after replacing all that it drives but after a little bit it will sputter and won’t accelerate unless I turn it off and then back on then it’s good for a few minutes and I ain’t getting no check engine light. Thank you!
It's time to check the ECU.
91ls400guy
02-24-20 02:17 PM
mikebatman
12
03-28-13 06:20 PM
