Locked my keys in the trunk
I've almost done this several times in the 20 years I owned this car, but I finally did it today. I opened the trunk to get my tennis racket and must have set the keys down inside and then closed the lid.
I got a ride home with a friend to get my other set of keys. But is there anything I can do at the scene? This car is too old to have any kind of wireless access, so I don't think Lexus can do anything. What about AAA? Do they have any magic?
Thanks
Thanks
AAA or a police officer would just go oldschool. Pry the door and coat-hanger the locks from the outside. A locksmith MIGHT be willing to pick the trunk key lock if you don't want to risk damage to the doorframe, but I'm not sure. And I guess it's theoretically possible to modify the trunk latch release system to have a physical button somewhere under the car that you've custom-added...
Cars are designed to be pretty secure unless you have the key lol.
ACKerr (09-30-22)
I'm not very familiar - but I don't think the manufacturer can just unlock things. MAYBE a dealer, at the dealer. But I'm not sure.
The closest parallel I know of is that they will have an app that turns your phone into a key. It uses bluetooth to connect locally and all you need is your phone. I don't know if you can just unlock the car with the app if you're not nearby or paired to the car beforehand.
I think Ca. has the most custom car shops in the country. (I could be wrong)
I do know what you're talking about with the manufacturer being able to unlock it wirelessly, you're thinking of something like *OnStar*. I've never heard of Lexus using that 20 years ago.
Oh yeah every modern car has wireless key fobs that's just a hunk of plastic with no actual metal key. You just keep it in your pocket or purse.
I like it as a system, it works great. Keys always stay in my pocket, you just walk up to the car, it unlocks, you get in the car, push the button and go. I've spent a lot of time in cars with this system and I've perfectly adapted to it.
The purse isn't always attached to you like your pocket is - so yeah I can see that being significantly less convenient if they like to keep their keys in the purse vs. a pocket.
So if she forgets her purse in the car it stays unlocked? I wouldn't like that feature.
And it turned out that I did not lock the keys in the trunk. They must have slipped out of my bag. I found them along the side of the fence. (sigh)
400fanboy (09-30-22)
Many times over the last 65 years I've locked myself out, one way or another, of my house, motor home, Jeep, truck, and various cars. I've always kept a key, or key box, hidden somewhere so I can get access if I can't locate my normal key. I even have a box hidden on my motorcycle and ATV!
For the Lexus, I have a key box hidden and secured from the weather and road splashes, that just contains the mechanical key so there is no transmitting to the lock or ignition. If locked out, I use that key to open the door or the trunk where I have a spare fob with the batteries pulled out. I like this as I always have a spare fob available if ever needed.
ACKerr (09-30-22)
+1 on keeping spare keys stored someone in case you get locked out. Not everyone has that luxury (you live in some apartment high-rise) - but if you do, bury a key in the yard! Not under a rock next to the front door, put it in a zip-lock bag and pick a random spot.
I have one key wrapped in plastic, in back, inside a phony sprinkler head in the grass. I also have a neighbor I trust who has a key for my front door. I suppose in some places, you might be able to leave a key with an office that keeps a locked keyboard. My mobile home resort used to have one of those.
Thanks
I like this idea. Where would be a good place to hide a key in my LS 400? I can do that while I am looking for the connector to the window wash fluid sensor so I can disconnect it. Is there a place I can tuck it or tie it or stuff it so that it won't fall off if I go over a bump?
Thanks
Thanks
It's hard to find a place that's not plastic that you can get to without crawling under the car. I took a magnetic box, glued an extra magnet to the bottom, wrapped it in plastic, then put it on top of the left front shock mount. It never moves and can't be seen unless you get down real low or remove the tire. Even then, it blends in with the background well enough so it's not noticeable even when looking at it. It just looks like the top of the tower. To reach it or check it to see if it's still there (which you will do a number of times until you realize it's not going anywhere.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
This would probably work for all models, I should think.
CAUTION: your arm and hand will get dirty from the top of the tire and plastic until you have faith and quit checking.
https://www.homedepot.com/p/Hillman-...1327/100162156 These work great, had one on all my cars and never had the magnet fail. Not my Lexus though, I only have the one key now. If I lose it I'm screwed.
That may be, but:
1. How many will care?
2. How many will do anything?
3. How many know where I live?
4. How many know what my car looks like?
5. How many will have the opportunity?
6. My car is always garaged when not being used.
7. My car is not a frequently stolen car.
8. An amateur would just break my driver's window glass.
9. A professional would use an electronic key bypass (?) off my fob which is unprotected while being carried. Or:
10. A professional gang would just hook up a tow truck.
11. I don't live in a high vehicle theft area.
12. I have insurance.
So, what is the chance of being stolen compared to the chance that I can help other Lexus owners? As to the house, all a burglar has to do (when I'm not here) is break a window to get in anyway.
That may be, but:
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
ACKerr (10-19-22)
