Bluetooth adapters that plug into the cigarette lighter outlet
An article in the local paper recommended this gadget. If I understand it correctly, it will allow me to answer my iPhone hands free and can also transmit music from my phone to the radio.
Does anyone have any experience with this device? Is there something else that is better?
Thanks
Amazon.com: Nulaxy Wireless in-Car Bluetooth FM Transmitter Radio Adapter Car Kit W 1.44 Inch Display Supports TF/SD Card and USB Car Charger for All Smartphones Audio Players-KM18 : Electronics
Thanks
On road trips they can be annoying as you'll have to frequency hop a lot to be able to find clean channels. But if you stay in the same general area generally you set it & forget it. Audio quality is fine, nothing to run home about but fine.
As far as I'm aware, there are no "good" quality devices. They're all cheapo Chinese junk. Some models when paired with some phones may or may not give weird bluetooth problems with random disconnections for no reason. But modern cars with expensive infotainments also do that so what can you do.
They get the job done for a couple bucks which is a hell of a lot cheaper than a head unit or full audio system.
Thanks
i use something similar and it works fine for my needs which are just to stream my own music/podcasts. sound quality isn't the best and the volume output is low - at least on my model so read the reviews.
i don't use the hands-free feature as it uses your phone's microphone which i usually keep in the cupholder so i would have to hold it anyway for the other party to hear me defeating the hands-free purpose.
it sure does beat hardwiring an aux cord or buying a capable aftermarket headunit.
ACKerr (10-19-22)
I would recommend buying them from a physical store, keeping the receipt, and if it doesn't work or gives weird issues just return it. A lot easier than Amazon.
Thanks
Thanks
sulkinator
ES - 5th Gen (2007-2012)
05-18-19 04:33 AM
