Aggressive shift from p to d
9th Gear
Hey guys, I have a 1996 ls400 and I’m having issues with shifting. When I shift the car out of park to drive, or to reverse, It jumps harshly. It does not happen when shifting into neutral and I don’t have any issues while driving. The ECU is not the issue as I had it rebuilt just a couple months ago. Could it be shift solenoids? I’m not sure but any advise would help a lot, Thank you!
Sounds like motor mounts are bad, or maybe just the tranny mount. When you put the car in gear it gives the engine alot of torque so the engine will try to move, or jump.
Do you have vibration on the shift lever? == tranny mount
Whole vehicle shake when engine running, especially in gear?== motor mounts
9th Gear
Based on everything I’ve read online it feels like your first stop should be the tranny mount. Do you know how many miles you have on your tranny mount?
When you come to a stop at a stop sign, does the car clunk and take a second to transmit the power after the revs jump? Is there audible clunks to these feelings you're having? If so, suggests transmission mount just like everyone else. If not, we'd need more diagnostic information.
If the mounts are original, they're no longer good anymore. Rubber doesn't last 20+ years, I guarantee you they're either torn, sagged or collapsed or all three. Replace them and you'll be amazed at how much NVH reduction they actually do. Only use OEM Lexus mounts, don't cheap out, they're not created equal.
