Transmission drain plug and washer part number
Have a 98 LS400. I can't figure out the washer and drain bolt part number.
I'm assuming they're not reusable right? I'm planning to drain and refill from pan multiple times.
So any help on the part number,
This was confusing
https://www.lexussouthatlantaparts.c...&searchString=
https://www.mylparts.com/oem-parts/l...olt-9011906866
This was confusing
Sherl (11-10-22)
You want numbers 2 and 3 below.
When I do multiple drain & refills at one time, I remove the drain plug and temporarily replace it with a Fumoto drain valve (F124N).
You dont have to drive the vehicle around (just shift it through each range) so there's no risk of ground clearance impact. Just replace the valve with the plug after the final drain.
FWIW, here's a dilution calculator image (for the A650E) showing how many drain/refills you need to get x-% "clean" fluid. It's hypothetical but close enough.
Use T-IV or an equivalent ATF. I use Edemitsu TLS (Toy-Lex-Sci).
- P/N 9008034016 (Drawing Item No. 35104A), Transmission Drain Plug (Rear), fits into two places in the the transmission case; one in the front side, one in the rear side.
- P/N 9034110011 (Drawing Item No. 35106A), Transmission Drain Plug (Front), fits into the pan.
- P/N 3517830010 (Drawing Item No. 35106B), Gasket, mates with P/N 9034110011.
Sherl (11-10-22)
https://www.amazon.com/Fumoto-F124N-.../dp/B079RXC9FN
thanks. great info here!
ralphgag
ES - 6th Gen (2013-2018)
07-10-21 09:40 AM
ramram55
06-11-18 09:41 AM
schmoozer
04-29-13 04:58 AM
