Just got clears for my 00 Ls400...i need to find red LEDs to put in them...anyone have any bulbs they used or know the socket type?? The bulbs i bought for loose as heck. Thanks!
7443 for the dual low/high brake lights (you will need 6 bulbs total).
7440 for signals.
i highly recommend sylvania LEDs. though pricey they are the best performing ones out there. other non-name brands just don't compare!
zevo are lifetime warranty, but you can also get the regular LEDs from sylvania for the same performance w/o the warranty.
keep in mind if you run LED bulbs you will need a load equalizer or your dash will complain you have a brake lamp out!
7440 for signals.
shoot...those are the same bulbs i got:/ they fit in the wiring harness but don't fit right and end up falling out...maybe my harness plugs are worn out, idkkk!
turns out i did buy the wrong bulbs but they look identical! I will buy those ones instead!!! Thank you‼️
