Can anybody identify this?
Definitely blown. Appears to be a Zener diode. Also take a close look at those electrolytic capacitors. If the end is swollen, the cap is bad and could be the cause of the diode blowing out. These are all replaceable.
mikemikeo (12-10-22)
It's one of Zener diodes used at the injector driving circuit. The purpose of those are to protect injector driving transistors from the surge. I imagine that your engine's one of cylinders is not functioning.
Even as I get older I learn something knew every day.
Yamae could you describe some of the trouble symptoms of this diode going bad?
This may explain the P0301 code that remains persistent in mine. I've checked that the cylinder is getting good spark, the injector is ticking/pulsing like the others. I'm unable to get individual injector output from my code reader so that remains an unknown. There is a distinct smell of gas at the tail pipe. Short and long term fuel trims fall in "normal" range but I suspect that that particular cylinder the injector is delivering excessive fuel for the misfire condition.
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/986x655/injectors_waveform_a9ce1438456d510e623e7f3ef61f4928b2afae6c.jpg)
Thanks Yamae.
Will need to pull the ECU to inspect those diodes. I really dislike how slow the code reader is to run the scan, in that time it is dumping lots of gas through that cylinder. The alternate path would be to pull the injector but that's not a task I look forward to for a quick session. All that brittle plastic concerns me when pulling the intake plenum and fuel rail to check the injector.
Thanks Yamae.
The best confirmation is to observe the waveform. If not available of it, there is a way to measure just the voltage of the injector using a multi meter. The voltage varies depending on the engine's load and the rpm but all the cylinders should show almost the same voltage. Compare the voltage and if there is the difference, the injector itself or the drive circuit in the ECU is not OK.
Also there is another way to check when the engine is off. Use an ohm range and measure both the resistance of the injector and the resistance of the drive side removing the 2 pin connector coming from the ECU to the injector. These measurement results and the comparison may tell you that it's the injector or the ECU that is causing the problem.
RA40 (12-15-22)
BIGCTY
SC- 1st Gen (1992-2000)
14
05-13-10 12:48 PM
