HELP Strange noise
I'm not sure if I'm able to post videos on here, but I'll post the link to the youtube video. But has anyone ever heard this noise and know what it is?
This noise happened before I sent my ECU to get fixed because I just assumed that it went bad on me. So I'm hoping I don't have to spend anymore money if this was the noise that caused my car to break down.
Short story, my car died one night and wouldn't start back up after attempting to jump it, I replaced the battery, the car started up fine and drove home with no issues at all. The next morning I start my car, I hear a small subtle noise, nothing too loud that would concern me. But 5 minutes later I'm in my house and I hear this screeching noise. I immediately turn the car off. I decided to disconnect the battery and reconnect it a couple of times and start the car back up, it made the strange noise two more times after starting the car and then went away. Now comes the second sound, it sounds maybe like valve ticking? I'm not sure, but I wanted to see if I'd be able to drive to work so I drove around for a little bit and then the car just fell on its face. the car had no power at all, it felt sluggish and not drivable at all.
Maybe some belt or tensioner went loose? I'm not really sure what it is and was hoping maybe someone in hear has experienced this before and figured it out. I'm still waiting to get my ECU back to see if it starts and runs fine, so im not really able to tell what's the actual cause of my car making this noise.
yukinon (12-16-22)
Fortunately the sound went away after taking the belt off and running it. A look under the hood while it was running showed that the harmonic balancer was shot, wobbling and causing the belt tensioner to make a horrible knocking noise with the belt on.
Definitely check the belt drive components first.
The following 2 users liked this post by fondu:
Entropic86 (12-14-22),
yukinon (12-16-22)
What Fondu said. If you're lucky it's something in the serpentine system. Take the air intake off and listen for where it might be coming from. Turn it off and feel for play in the serpentine idler and tensioner pulleys. Let us know what you find.
yukinon (12-16-22)
I had a similar sound happen out of the blue and every mechanic i brought it to said it had to be coming from inside the engine.
yukinon (12-16-22)
Sounds like it could be caused by a harmonic balancer wobble. It's always a good idea to check the HB anyway cuz the rubber gets hard and deteriorates. I've seen a few threads here with failed HBs and it aint too pretty when they split and cause some major damage. I changed mine a couple months ago cuz of cracks and splits in the dry rotted rubber which got rid of a little bit of shake.
did you order an oem specific HB or will any manufacturer be fine? was it fairly easy to replace? i definitely don’t mind doing things on my own but it’s pretty cold and it did snow recently so it’s gonna suck lol.
i’m definitely gonna check that when i get time this week! i’m assuming i should check if it’s loose by wiggling it?
I didn't go with OEM when I changed mine (financial and other reasons) I went with Dayco.
It only took me about an hour of working time. I did mine from the top cuz I didn't want to crawl underneath. I only needed to take off serpentine belt, fan with clutch, and then the HB. (missing fan shroud) From the bottom, after removing serpentine belt there's only the engine undercover and you can get to the HB.
I used this tool to hold the crank while loosening the bolt. (22mm)
![https://www.amazon.com/Yoursme-Crankshaft-Harmonic-Balancer-Holding/dp/B07QPNNC55/ref=sr_1_1?crid=323665Y39J0IR&keywords=Yoursme+for+Lexus+and+Toyota+Harmonic+Damper+Pulley+Holder&qid=1647524766&sprefix=yoursme+for+lexus+and+toyota+harmonic+damper+pulley+holder%2Caps%2C141&sr=8-1](https://www.clublexus.com/forums/images/misc/amazon_icon.gif)
