1990 Ls400 suspension question
I want to have a little bit of fun with my ls before i get my coilovers and me and my friend want to put it on washers ( i know its probably not the best thing to do but it wont be for long just want to have fun) does anyone know what size will fit?
perhaps you meant spacers, as in for the wheels to be pushed out? or spacers to RAISE the car?
the washers go in place of the springs, on the strut shaft, it makes the car lower and is stiffer, its not good for the car and it is stupid and i know that but thats why i only am doing it temporarily since i am getting coilovers soon
@OP - wait for your coilovers, and lower the car the right and safe way. There are lots of threads about this
Riding on washers is not fun, and I don't think anyone wants that kind of liability. If you wreck, your friend isn't paying for the registration & insurance on your car.
EDIT: The struts aren't designed to work without the springs. They will blow out if you put the entire weight of the car on them, and your car's handling will be incredibly poor
I'm not sure which would blow out first, the shock absorber or the shock mount. Is it possible you could punch straight through the mount and through the hood\rear window if you removed the coil springs that actually carry the weight of the car? Since the mounting point of the shock absorber, and thus that weight, is going to a different point on the mount than the coil spring normally distributes it to.
Even if that's not the case, it'll be riding on the bump stops the entire time and basically be un-drivable. As in you hit a pothole and spin out un-drivable. This seems like a horrible idea. Wait for the proper parts.
hmm i've never heard of using washers to offset the strut shaft, since the shaft has a bevel to prevent the shaft from going all the way through.
i suppose you can remove the beveled washer and raise the shaft into the cabin/engine bay...but that's just asking for bad news if it fails due to the added tension on the springs!
as with what everyone said, just do it right the first time!
I think he means washers on the shafts of the struts.
Well it's your car to do what you want with, but please don't have fun on the public roads where we're all driving. In the parking lot? Knock yourself out bud. I just hope it doesn't break something unrepairable when you hit a big bump.
(this being said - I know there are a shocking number of cars with rusted frames and non-functioning brakes driving around out there - a "friend" of a friend of mine has a truck whose rear leaf springs rusted through the frame and are sticking out of the bed, so yeah).
Scraape
10-23-16 11:32 AM
