Left speakers play at lower level than right speakers??
Hello, I have a 1996 ls400 with the stock pioneer sound system, both front and rear left speakers play much quieter than the right side, and no it’s not because of the balance. I’ve checked the front speaker and tweeter and replaced them with some new oem speakers but that didn’t solve the issue, any advice would help, thank you
i would start with checking the amplifier under the passenger seat and make sure all connections are good with no spilled drinks or loose connections, esp at the wiring you highlighted.
next i would check the trunk harness where the cell phone wiring would go (i believe it's under the floor on the right side). again check for loose connections or water damage. it sounds like the cell phone transceiver is muting things as if you're on a call.
