98 LS diff options.
98 LS diff options.
So i got a 98 LS400 and the spider gears in the rear diff are about to go. I know its been posted before but i am having a tough time finding a definitive answer. I want to get a limited slip of some sort so i don't have to worry about blowing the spiders up again (All the one tire burnouts did her in lol). Nobody seems to sell anything that fits an LS400 but i can find them for GS's, mk4 supras, etc. apparently the 98-00 use the same 200mm differential and in theory a limited slip carrier for a GS, SC or mk4 that use the 200mm diff should work? I'm quite proficient at ring and pinion setups so that part of it is not a concern. I just don't wanna drop a thousand on a carrier that won't work. Thanks
I have never installed this myself, but from reading and researching this before, you are correct 200MM is what you would need.
Here is a good one ive seen, its made in UK by this shop:
https://www.cbsracingshop.com/en/200...-aristo-soarer
https://kaazusa.com/product/supra-jz...5-way-dbt3020/
honestly i would opt for just a clutch type diff. Wish someone would make one in the $500 range. Perfect for a daily with some spirited driving. I don't really need to spend $1000+ for a daily's diff but i guess i will if it's the only way lol
i came across this and thought it might be a good option:
Yeah i hear you on that, if there was something for 500$ range i think there would be a lot more of these older lexus's with LSD's in them lol. would be nice.
There is a russian made LSD for our cars that used to be available on ebay for about $700 if I remember correctly? But seems like it disappeared off ebay when this ukrain war happened
That KAAZ isnt a clutch type is it?
RelentLex (02-10-23)
BNastee (02-14-23)
I would call it verified actually. I've seen several cars online reportedly using 200mm LSDs and it works. LS400's, GS400's... 200mm works.
Cannonbear
Performance & Maintenance
11-21-04 04:56 PM
