Hello. Several months back I posted about this code on my 95 Lexus LS400 and it was recommended I get the solenoids and replace them, which I did in January. Unfortunately, the "check engine" light is on now again and, once again, I have a PO758 Code. Any thoughts on what to check next.
FYI - shifting into any gear is smooth except for when the car engine is warmed up, at which point I notice a slight hesitation / slowness going from 1st to 2nd gear and now I have a flashing ECT light on the dash.
I'm a senior citizen, not a mechanic, so your advice/guidance is appreciated. TY
Yes, the original transmission was maintained and the replacement one is maintained but I will have the fluid checked and flushed if necessary. The transmission was replaced last June and about 6 weeks later the code PO7658 showed up. This code which is for the "B" solenoid and both "B" solenoids were replaced as were oxygen sensors.
The mechanic recommended I find a Transmission Valve Body Wiring Harness for the 1995 LS which is easier said than done. So far no luck. The shop told me the clips on the wiring harness are broken. Anybody know if the clips can be purchased for the wiring harness. I haven't been able to find either the harness or the clips.
thank you. I could not see enough information to identify the name of the company to do a search. would you pls provide the company name and how you found the above items. Did you search on wiring harness. In my case, I don't know the part number. Thank you for your help
