ticking valve after being parked
Hey guys,
My '99 LS has been parked for a week or so, and on start up there is one or two valves that are ticking. I thought, well a lifter probable bled out and it should be fine. But then I remembered that these things don't have hydraulic lifters...
I am not yet able to wrap my head around the fact that it started ticking after being parked, goes silent after a couple of minutes of running, and goes thicking again with cold start.
It started doing it out of no where.
Anyone got an explanation on this?
Thx
kevin
Thx
kevin
Google is your friend...
"valve tick when cold forum 1uz"
https://www.clublexus.com/forums/ls-...ed-in-1uz.html
Some valvetrain noise is normal for our engine. I imagine what you mean is 1 or 2 valves are making "abnormal" noise.
How has the oil maintenance & health been on your car? If the noise goes away as the engine warms up, this sounds like an oiling issue.
Hey guys,
Thx
kevin
Thx
kevin
paulo57509 (02-26-23)
That is what I said myself already.
It has the symptoms of a hydraulic lifter but I realized it doesn't have them. I mean, I've checked clearance like 1.5 years ago.
Oil and maintenance is fine so I don't have suspicions on that.
To me its just weird that there is no issue what so ever, and then all of a sudden when no one touched the car for just over a week it started doing this. I can't remember this has happened before because it is not the first time it sat for more then a week.
The thicking is loud enough to be concern when you hear it for the first time, a rod bearing was the first thing that went trough my mind but I think it's safe to say it is not. The reason it sounds so loud is probable because it's an exhaust valve where the sound is amplified by the exhaust manifold.
It's still parked atm, probable switch back to it next week or so and if it keeps doing it after I drove it I think I'll pull of the valve cover.
Btw, I have tried searching but most I found was the early 1uz while I have the vvti so i can imagine things are different / updated
What brand oil filter is installed?
It's a bosch, and in all honesty, I've never heard of an anti-drainback in an oilfilter. As far as i'm aware it is a pressure valve that opens in case the filter is clogged up.
Also, if it would be some kind of anti drainback valve that is faulty, you would have oil pressure at the head within a couple of seconds. Not minutes. So even though it's worth a try, I have my strong doubts
Many aftermarket oil filters do not fully meet the requirements of the engine manufacturers. I feel that BOSCH used to manufacture very good quality parts but after the financial crisis of 2008, they began to drop the cost a lot using poor materials and I am not a fan of BOSCH any more. They also start to manufacture products at lower labor cost countries where skilled workers are not easy to hire as well as quality materials are not easily obtained. Many local indies say," We can't expect BOSCH as it used to".
CELSI0R (02-27-23)
The red arrow is the anti-drainback valve. The yellow arrow is the pressure relief valve.
The purpose of the ADB valve is to prevent the oil that is in the engine oil galleries from draining back into the sump after shut down. Tell-tale signs of a failed/marginal ADB valve is engine clatter upon start-up that lasts until the galleries are refilled.
^^^^ I agree with paulo57509. When I bought my 93 last year I had a tick and couldn't figure it out. It wasn't the normal tick we all get from cylinder 7 (both my old 93 and 94 had it) But after I changed my oil, with an OEM filter, the tick was gone. I never researched into why it did that, I was just happy the tick was gone.
I learned something new about oil filters today. And here I thought "just any ole filter, it's just is a paper thing for filtering oil".
It turns out there really is a reason for everything. And especially, especially ESPECIALLY with this car... aftermarket is universally a cost-down, and never a match in quality because they cannot compete.
There are some filters I will never use again; Bosch and Champion Labs E-Core type filters (Super-Tech and some ACDelco), even though the E-core has been redesigned to prevent this. This is from 2017 was in service on the LS for ~5k miles.
Super-Tech "black" can ST3614
Yeah this car has re-written the book on aftermarket vs. OEM for me. I think overall, it varies a lot depending on the make & model of car. For some cars, they are such hot garbage out of the box that it's not difficult to replicate or improve on (I'm looking at you BMW plastics and gaskets). At the end of the day, it's all the same 14 or whatever suppliers for half of this stuff anyway. Half of Toyota's job is just assembling parts from component suppliers like Brembo, Bosch, KYB and Aisin. They come out with some new electronic thing-a-ma-bob and Toyota integrates it into their products.
