Won't start after stripping interior
It's as it sounds. I bought a 2002 ls430 a couple days back it was running. Since the last guy is a crackhead I stripped the whole interior obviously with the battery disconnected. I went ahead and plugged the battery back up now and it keeps cranking just won't start. I do have a check vsc light on. Any of you guys have experience/advice? Also my obd2 reader ain't connecting at all, it's getting power but can't connect to the car
I did remove the back seat. Pump wires seem fine, when I try to crank it I smell fuel. The conclusion I came to is VSC light is preventing the car from starting I could be wrong though
THats what I thought at first but still doesn't help.
It's a new battery but yea I'll clean the terminals. I do have to mention once I was working on the car and it just started pouring hard and the battery and ecm got soaked. You think this might be the problem? *Ecm cover was off cuz the crackhead lost it
Left on for 2 minutes with obd2 plugged in, still wasn't reading. Battery could be low tbh I think there's something draining it (left the battery in overnight). Before all it said was VSC ok the break wear light message wasn't showing. I would think ecu being fried would make it not do anything at all no? I did unplug and air-dry after it got soaked
My 2001 LS430UL will not work with the bluetooth obd2 reader as it will not connect and cause all sorts of lights to come on. Techstream works ok but half the time engine light and VSC lights stay on after using and I have to reset the zero point calibration of deceleration sensor in techstream to correct. I have heard this can happen and our cars only properly work with the dealer connections. That obd2 reader you have connected will drain the battery overnight just like leaving a dome light on will. If you are leaving this reader plugged in while cranking the car it could possibly be causing the problem. Try not connecting the reader and disconnect the battery to reset the ecu and don't put reader back in and see what happens. Also with the ecu did you take the metal cover off the top and see water in there? If so and above procedure did not fix then take metal cover off again and look for green corrosion around any parts that can be shorting out.
