Installing ATOTO S8 head unit and backup camera in 04
3rd Gear
I have recently bought an 04 Ls without the nav or screen. I plan on installing the ATOTO S8 along with the ATOTO backup camera. Has anyone done this?
Good luck. How does it interface with the factory amp or are you going to run a dedicated amp? You can tap the reverse light circuit in the access panel in the trunk on the left side. If you need the number, I can dig it up or I have the diagram around here somewhere from when I did my install on my non-nav 06.
3rd Gear
Send me a PM with your email address so I can email you the trunk wiring block diagram.
You need some way to interface with the factory amp. The BeatSonic works wonders and is what I used but I don't know how that works with what you have and trying to find one now is a real challenge as they've been out of production for some time.
They no longer make the interface kit for the nav or the non-nav cars nor do they make the mounting kit. Don't blame them considering our cars are 17 years old at their youngest. The nav kit is still easy to find used in Japan but the non-nav is a challenge given how few cars over there were optioned that way.
I have a 2004 LS430 and rather than gut my headunit, I bought a Carpuride W901 unit that has a rear camera interface, and plugs into the aux port of your stock radio... I don't kmow if that helps... but it helped me get Carplay in a 19 year old great car...
I had the Atoto S8 installed in the 01 ultra, It takes quite a while to be comfortable with all the multi multi multi settings. Had some issues with it - the support is quite good. Even after warranty expiration they are still helpful. Presently it takes almost 5 min before the sound comes on. Support has some suggestions but as a layman its out of my league to fix this. Audio tech charges over 100/hr. The rear camera does not work any more but I think I found the problem. The cable was installed too right. When opening and closing the trunk lid the cable got bend too much and eventually broke.
Would I buy it again? I am undecided. Even other toprated units have problems. I think it is a washout. For the first 4 months it worked flawless
3rd Gear
I think I am going to do this. Do you mind sending me a picture. I want to see how/ where it would fit.
05ls430518
07-29-23 06:31 PM
Parapiva
GX - 1st Gen (2003-2009)
11-25-21 07:40 AM
xewonder
NX - 1st Gen (2015-2021)
11-24-20 11:47 PM
