LS430 Sideview mirrors
1st Gear
My driver side mirror attempts to rotate but just constantly "clicks" like stripped gears when I start the car. Then it stops. It will not unfurl or retract.
Any suggestions on how to change without having to remove the door panel?
BigBoomer (07-24-23)
In the meantime, you should switch off the auto-retract and get the mirror where you need by using the adjuster whilst pushing/assisting the mirror.
You do have to remove the door panel, here is a link to another thread with two options to try and fix the issue, I've had to do this before with my LS, the only thing you have to be careful on is disassembling the mirror. https://www.clublexus.com/forums/ls-...irror-fix.html
