01' Trunk doesn't open
1st Gear
Hi everybody .My outside trunk button doesn't work. I pushed on the lock button inside and i dont have the key ( yes I'm an idiot...) I'm trying to take all the panel under the steering column but it doesn't come.
if you know the method, I listen to you please. Thanks to all for your help
Salut Pierre,
If you don't have the key, how do you start the car?
With the master ignition key you can unlock the security switch under the dashboard which enables the inside trunk release button, and you can also unlock the trunk with the same key, but if you only have the Valet key you cannot unlock the trunk.
If you only have the Valet key, then you will need to take it to a Lexus dealer and pay for them to provide/code a new master key for you.
dlovato
Hybrid Technology
11-05-07 02:31 PM
