Smart key issue
Smart key issue
Hello! Suddenly the car LS 2005 stopped responding to the smart key, won't lock, doesn't open the trunk from the button. . At the same time, the key inside the cabin works(the car sees the key) and the car starts. When pressing the key buttons, the light on the key flashes. I changed the battery, the button smart is active. What can it be?
Do you have another SmartKey? If so, test with that. If not, then you really need to get one ASAP as if you lose the one key you have you are in deep kaka.
If the other SmartKey has the same problems then it's probably the receiver for the system that has failed.
If the other SmartKey works, then it's the transmitter in the key that has died.
Afortunada (08-17-23)
Without a working key, you can't, unless you have a working knowledge of UHF (315Mhz) data communication systems.
I know I don't and I have a Radio Amateur license and worked in electronics for 20+ years.
You will need to go to a Lexus dealer and they will probably insist that you get new key to start with.
If that doesn't fix it, then they will be wanting to swap out electronics boxes at great cost.
Afortunada (08-18-23)
You are welcome. I still strongly recommend you get another Master SmartKey coded to your car. It's easy enough to do if you already have a Master Smartkey.
From the factory the LS430 came with 2 Master Smartkeys and one Valet Smartkey.
Afortunada (08-19-23)
"never mind". so I have only one key.
Getting an extra is not that expensive. New one from Belle Lexus on e-bay, about $110. Refurbished or generic aftermarket (perfectly fine) can be had for less. My Lexus dealer charges about $75 to program, a local Toyota dealer does it for $50. You can do it yourself with Techstream. Also, they do it cheaper if you are having other service done. A good local locksmith (getting harder and harder to find) will cut the blade for around $25. You can also transfer a blade from an old key.
All in all, about $220 for a new one with dealer programing. Less if you work at it. Strongly agree with those that say you should get at least one spare and keep it in a safe place.
Afortunada (08-21-23)
These are the 3 SmartKey types.
Type A is the early model.
Type B is the Valet key.
Type C is the Master key.
The Valet key does not have the trunk button and the slide out key in it will not give access to the Trunk nor to a locked glovebox.
From the factory they were supplied with 2 Master keys and one Valet key.
The following 2 users liked this post by BigBoomer:
Afortunada (08-21-23),
funcrusher (08-21-23)
I only have one key, type C(Master Key). I need to order the original key, type B, right? Well, first of all.
