Need help with some dead fuses
My MPX-1 MPX-2 MPX-3 and DOME fuses are not getting power when I tested them with a voltometer resulting in some of my cluster lights not working as well as some lights and electric key fob locks
Ok that is the first step. I am assuming you have disconnected the new amp and sub to see if any difference. Where did you get the power source for the sub and amp? Do you have or can find a wiring diagram and know how to read it once acquired? If not I will be back home early next week and have full manuals and will help you diagnose the problem. You have a main power source that is missing and I can trace it backwards to see where the problem is. As I said before it is either a fuse open or burnt into wire and hopefully not a control unit. We will be able to pinpoint exactly where the problem is. Another thought is to look around everywhere you were when installing new system and make sure no connectors are unplugged.
It is hard to tell without voltage measurements at right places. Thought you said this happened when installing new system. Did you have to touch that fuse box any at all for installation even moving? (important to know)
no I didn’t mess with the trunk fuse box during installation, December of last year some water had got in and I got it all out and that fuse box ended up working still, just had some condensation on the inside
Great... I see you are in CA as I am in NC. Post here Sunday sometime if you still need my help and I will look into it Monday morning. Also from previous question where did you tap in for power for new system?
the 2 power cables are on the battery terminal and the grounds are in the trunk under those latches.
Great...need to know all this for diagnosing. You might want to add a manual high amperage switch (generally a circuit breaker with manual lever) if don't drive car a lot for battery drainage as constant power keeps capacitors charged in amp. Let me know Sunday if still need my help
werewolf
GX - 1st Gen (2003-2009)
04-21-22 01:07 PM
twojayzee
GS - 1st Gen (1993-1997)
08-16-14 01:53 AM
spinedoc
04-02-01 07:12 PM
