Radiator hose clamp part number
If you want to use the original Mubea/spring type clamp, you can actually get those at most Ace Hardware stores w/o special ordering. They have up to 4” size. Smaller ones are in the pull-out drawers, larger ones in blister packs hanging.
It's showing a few different part numbers.
2001-2003
Upper engine side (all) 90466-41003
Upper radiator side (all): 90466-41008
Lower (both) 90466-41008 (08/2000 - 01/2002)
Lower (both) 90466-41003 (02/2002 - 06/2003)
2004-2006
Upper and lower (all four) 90466-A0026
Thanks for everyone's help. I need to order front brake pads, rotors, and rear struts so I'll just add the four clamps to the order. It's good to know that Ace carries these constant tension clamps if I'm ever in a bind.
ChevelleZZ502
ES - 6th Gen (2013-2018)
11-06-23 10:24 AM
