Apparent oil leak near oil filter. What usually leaks here? What parts to replace?
I removed the big bottom underbody protective cover and cleaned the engine compartment with brake cleaner.
I did some driving and a couple days later, about 25 miles or so, I took the picture I have included here.
I cant tell for sure if the oil that is on the oil filter bracket is leaking from the bracket or if it leaked down from the crank seal.
I lean towards diagnosing the leak as being from the bracket, maybe the sending unit / sensor.
So, is there certain parts that are most likely to leak in this area?
What do you think it is?
I have included a picture of what appears to be leakage from the crankcase seal, and a picture of the oil filter bracket with a drop of oil... Yuck.
Any insight appreciated.
High probability it’s the oil level sending unit gasket located aft of the drivers side motor mount. It’s a PITA to change. Might as well do the motor mounts if it’s leaking. Car Care Nut You Tube has tutorial about this in the Motor Mount R/R episode.
https://youtu.be/i5LYL1zPP-8?si=RP8g8vg5XN0CVHpI
@12:15
@12:15
