What is this sound at Start up?
My 2003 LS430 is stuck outside a Panera. Help! The vehicle is making
when I turn the keys over. Gas tank is full, plenty of electricity. I still jumped it to be sure. No change. You can hear a sound like something is spinning, and then a click.
Yamae (05-16-24)
BigBoomer (05-17-24)
Thanks. It's kind of funny. I found these videos with "The Nine Sounds a Bad Starter Will Make and Why!" and after watching 3 of these...none of the starters sounded like mine. None had the spinning at all. I'm pretty handy and the vehicle is only an 1/8th of a mile (uphill) from my drive way. But based on a little research I've done there is no way I can get it started (it is an automatic). Looks like I'll be calling a tow truck in the morning.
If it is making that sound the starter bendix is bad or a bad tooth on flywheel. In either case need to pull manifold and replace starter even if good. Another thing to try is turn crankcase pulley to move flywheel before teardown.
