Side mirrors don't hold consistent positions
I have a 2002 LS430. I recently noticed that the side mirrors' positions are frequently slightly off from the preset positions and have to manually adjust them. I have the mirror sset so that they tilt down in reverse and fold in when the car is turned off. Has anyone else experience the same problem?
I have the same problem on my '90 LS400. It drives me crazy, but considering the age of the car, I can't complain too much. You on the other hand have a 2002— it should not happen!
Anybody have advice on dealing with loose mirrors? Can they be tightened up?
Guys
You will find that the cause is either of the following:
1. The mirror rubber gasket between the mirror casing and pivit is worn or shrunken; or
2. The screws under the mirror that attach the mirror casing to the body post are loose.
I hop this info helps.
I had the same problem on my 91 LS and resolved it by gluing in a flat rubber washer.
Seasons Greetings
PSLS400
Seasons Greetings
PSLS400
