Adding on XM radio
Adding on XM radio
Hey all...
I was wondering how I can go about adding XM Radio to my factory system? And will I be able to see the stations and select different stations through the Nav LCD?
Thanks,
Ray
Thanks,
Ray
I had the XM Radio added to my '04. They installed it without the outside antenna by putting the antenna in the rear deck brake light. It works great and the reception is fine.
You can pre-set stations and view them through the touch screen. I think there are three groupings of six each (SAT 1, SAT 2 and SAT 3). You can change channels either with the pre-set buttons or manually with the dial on the right side of the radio.
