High Altitude driving
I am planning to drive my LS430 from PA to Colorado/Utah for a 2 week vacation. Yes I know that sounds crazy!
I am planning on driving up Mt Evans (14000 ft) and the Trail Ridge Pass (12000 ft). Does anyone know if the car will have a problem with the high altitude? I am leaving in June and probably need to factor in snow as well. I could drive my wife's ML350 instead, but I far prefer my car. Any thoughts would be appreciated.
I agree with everyone, and also keep in mind that as long as you are up at 7-8000 plus feet- you don't need premium fuel. It will be a waste of money, and you can't get 92-93 octane up there anyway. The lower grades are required by law to contain the same detergents and cleansers as the premium fuels, so you won't "hurt" the LS at all.
If you use lower octane fuel at altitude, you may gain some of that torque back as a side benefit to saving some coin.
Good luck and be safe-
You will notice some loss of power. This is normal and you have nothing to worry about. Since the speed limit is like 35 mph on those roads, you might not even notice the loss with your V8 LS430. You may feel sleepy while driving in high altitude due to lack of oxygen. If so, pull over and take a nap. Being from near sea level, you should take your time going up the mountains.
If you have trouble starting your car, you may have "vapor lock." Simply open and close the gas cap, then wait a minute before cranking again.
Enjoy your trip and drive safely. This is the best time of the season to see Colorado and Utah. I will visit Trail Ridge as well. Look for a white/grey RX300 with black bumper guards.
Your engine's computer will compensate for the thinning air as you gain altitude by cutting back on the fuel supply to maintain a constant ratio, so with a normally-aspirated engine there will be a noticible loss of power, especially at 10,000 feet or so and above. This is normal....so give yourself extra time and room for passing.
Harrier also gave some good points about vapor lock and the effects of altitude on your brain. By all means do not continue driving if you feel drowsy.
Originally Posted by 3rdelement
my car runs horribly here at high altitude with low octane. I actually run best up in the mountains with 93 octane. odd!
Thanks to everyone's very informative responses. I can't wait for the trip. Going to take a lot of photos. I'll also end up in Bryce Canyon, and then to the Vegas. Long trip, but couldn't think of a better car than my LS430 to take!
DigMyM35x
NX - 1st Gen (2015-2021)
05-03-15 07:30 PM
machinegt
SC- 1st Gen (1992-2000)
12
07-09-02 01:20 AM
12what, altitude, altitudes, california, car, driving, experience, expierence, high, highest, ls400, octane, older, problem, texas
