News Flash !!! 2005 Ls430 Lights Fit 2001-2003!!
Old 08-07-05, 09:53 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by JLAWS
Tell me more about disabling the lighting computer. Do you have info on it? I don't care that the cars doesn't tell me that my signal light is out etc. If I can disable it I won't need the "dummy bulbs" which draw additional current since leds don't draw enough thus the taillight failure message.
One guy in the GS forum had an entire thread where he explained how to disable the ECU. Im going to try and find it.
Old 08-13-05, 08:57 PM
NayC55
NayC55's Avatar
If I can find a black 2004-05 trunk with lights for an extremely cheap price then I'll do the complete transformation. I think another LS430 owner is doing that and we may hear from him with the results. But for now the look right now is just fine. All I get is compliment on the new look and NO ONE thinks it looks abnormal.
Will a '04-'05 trunk fit on a pre-'04 w/o any modification?
Do you have a link to the thread where you saw the other member who was attempting the exchange?
Thanks.
Old 08-13-05, 09:33 PM
gs4to4
gs4to4's Avatar
I have an 01 LS430 and I bought the 2004 inner and outer tailights as well as the 2004 Trunk. But the 2004 trunk that I have is missing the lock assembly and latch assembly. I planned on transfering the lock and latch from the 2001 to the 2004 trunk but I didn't get the chance yet.
I'm not even sure if the lock and latch assemblies from my 2001 will fit into the 2004, does anyone know?
I also need the center trim peice for the 2004 model (the peice with the "L") so if anyone has it, please PM me.
Thanks
Old 08-26-05, 01:45 PM
JLAWS
JLAWS's Avatar
Ok here are some pics. They are pretty crappy since they were taken with my bros camera phone. I 'll get better pics eventually. You can draw your own conclusions from these pics....
File Type: bmp
Old 08-26-05, 01:46 PM
JLAWS
JLAWS's Avatar
pic 2 not any better
File Type: bmp
Old 08-26-05, 03:44 PM
rominl
exclusive matchup
rominl's Avatar
well i always like the clear taillights more, but the fact that the inner taillights don't line up well, that's kinda bummer. otherwise, it's a good improvement
Old 08-26-05, 05:34 PM
JLAWS
JLAWS's Avatar
I'm just waiting on "gs4to4" to confirm that the trunk fits fine with no complication then I may do the complete change over if I can find them at a reasonable price. But for now the look IS an improvement.
Old 08-29-05, 02:23 PM
LexLaw
LexLaw's Avatar
That clear tail is definitely an improvement. I don't know why still even make amber lenses in rear tails. That's so 1900's
Old 07-19-07, 01:34 PM
FBburn
FBburn's Avatar
Ok, so here's the trick. Its fragile & kinda Martha Stewart, but its worth it...
-Remove your Taillights.
-Heat your oven to 125 degrees.
-Stick your tail lenses in for 2-5 min.
(depending on pre-heat time)
-Check them every 30 sec or so
-Once the seals are loose, remove them from the oven.
-Separate the lens from the housing.
-Remove the orange reflector from the lens.
-Replace orange with clear.
(It will now look just like the red/white lens next to the rear trunk lid)
-Put it back in the oven briefly
-Remove & Reseal.
-Heat again for 45-60 seconds.
-Remove, let sit until seals are firm and Re-install.
I've done this on two SC400's, my folks '01 LS430 UL, & will be doing this to my LS430 UL once my broker finds the '04 I'm looking for...
Just keep in mind, this is a delicate process but, when done right, its flawless.
New here...just thought I'd share this with you on my first post! I've gone through 5 Lexus myself, also 2 Bimmers, 2 Range Rovers, a twin-turbo Supra, and, at present, an '02 S600. Looking forward to dumping the '02 S600 for my '04 LS430 UL! Btw...thank you, all of you, for such informative threads! Much Luck! -FB-
Old 07-19-07, 02:06 PM
bigcory
bigcory's Avatar
These Posts Are Nearly Meaningless With Out Pictures!!!!! : )
Old 07-20-07, 11:19 PM
FBburn
FBburn's Avatar
Has anybody tried these?
http://www.autoaccessorycyberstore.c...tail?no=414237
Old 07-21-07, 01:55 AM
eyft23
eyft23's Avatar
-Remove & Reseal.
will this work on the headlights also? i want to get rid of that unsightly amber reflector in my headlights on my 03 ls.
Old 07-24-07, 02:20 PM
912inc
912inc's Avatar
^^^^^ yeah, is it going to be a PITA to open up the headlight, i want to take out the amber reflector...
Old 07-30-07, 02:00 PM
Boomer01
Boomer01's Avatar
What do you mean by this? Do you have to go out and buy a clear reflector? If so, where?
Old 07-30-07, 04:25 PM
912inc
912inc's Avatar
I think you only need to take out the orange part, but I think the JDM one is clear, but correct me if I am wrong
Quick Reply: News Flash !!! 2005 Ls430 Lights Fit 2001-2003!!
