Daylight Savings time?
Old 10-31-05 | 02:51 PM
DDLexus's Avatar
DDLexus
Default Daylight Savings time?
My clock didn't adjust for Daylight savings time? I thought NAV equiped cars would automatically adjust to the correct time? Anyone else notice this?
Old 10-31-05 | 02:54 PM
lkirchner's Avatar
lkirchner
Under options on the menu there is an icon for daylight savings time----- yes or no. My wife's adjusted correctly.
Old 10-31-05 | 05:53 PM
BMcD430's Avatar
BMcD430
DD - I noticed the same thing - and I had mine set to observe daylight savings time. I went in and set the daylight savings time to NO and it instantly changed back to the correct time. I too was under the impression the GPS could "recognize" this change. Small inconvenience.
Bruce
Old 10-31-05 | 05:54 PM
BMcD430's Avatar
BMcD430
What's with all these words getting the double underscore hotlinks in all the posts now? Is there a way to shut that off?
Old 10-31-05 | 06:01 PM
Neo's Avatar
Neo
The One
https://www.clublexus.com/forums/sho...d.php?t=182100
Old 10-31-05 | 06:25 PM
BMcD430's Avatar
BMcD430
Yes, Neo - You ARE the one!
Thanks! I too thought it was something my laptop had picked up during it's travels.
Old 10-31-05 | 06:48 PM
DDLexus's Avatar
DDLexus
Bruce
Thank you. I made the change and it works as designed now
Old 11-01-05 | 10:25 PM
aerodragon's Avatar
aerodragon
guys-
I am still not sure here- when I selected "OFF" on daylight saving, it will properly show the correct time; isn't this counterintuitive??
Old 11-02-05 | 01:31 AM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Originally Posted by aerodragon
guys-
No, its not. Not all States follow DST, so you have the option of turning it off and on. Next year, DST will be pushed back 2 weeks or so, so be glad your LS didnt change when it was supposed too, otherwise you would have some issues next year.
Old 11-02-05 | 03:48 PM
encore888's Avatar
encore888
Sorry to be obtuse, but does the LS change automatically or not?
I changed the clock settings on Saturday in the clock menu, just as I was changing the clocks all over the house and my watch. I didn't get a chance to see if the clock would change automatically, although a friend said his Acura TSX changed on its own.
Old 11-02-05 | 09:46 PM
RAristo's Avatar
RAristo
I thought when I selected "Auto", it would automatically adjust to DST. Guess not.
Old 11-02-05 | 10:15 PM
encore888's Avatar
encore888
So it doesn't change...you just change it yourself then. OK!
Although the manual says 'clock can be set manually or by using signals from your GPS'
Old 11-05-05 | 02:58 PM
Robert Kon's Avatar
Robert Kon
Question Daylight Savings Time Adjustment
I noticed it also. I live in NJ and mine didn't adjust automatically. I also read in the manual that the GPS Nav feature should take care of it. However I had to shut the DST option off to manually correct the time (push back an hr) but after I corrected it and then turned on the DST option the clock jumped ahead an hour. I then turned off the option. It appears not to work correctly.
My 5k maint. is coming soon and I plan to ask the dealer.
Old 11-05-05 | 03:07 PM
aerodragon's Avatar
aerodragon
that would be great if you could update us on what the dealer says.
Old 11-05-05 | 03:15 PM
Rockville's Avatar
Rockville
Default The Daylight Savings Time switch...
needs to be turned off. The time is automatically set for your time in your timezone but not for Daylight Savings, hence the switch. Any more questions about your LS?
Rock
