04 HID question
VIP|EXEstyle セルシオ
Definitely not plug and play since they're completely different headlight housings. It might be possible to retrofit a projector in there, but it's going to take a lot of work.
JLAWS has successfully swapped the outer sections to the newer 04+ LED tails:
https://www.clublexus.com/forums/sho...d.php?t=187626
https://www.clublexus.com/forums/sho...d.php?t=166245
p.s. Moved to the correct forum.
thanks for your response brian and henry. i thought the headlight housing were the same shape but you are telling me otherwise. i didn't think the 04 front end changed that much where they would design a new headlight shape.
i know you can add a projectors on the current 01-03 reflector but was hoping the 04 as a direct swop.. darn..
thanks for the info on the tail lights but it doesn't line up..i hear good news on the ebay outer lenses but someone said they will turn pink when it ages..
i'm looking into this info because my father in-law just bought a 02 ls430.
exclusive matchup
actually the 04+ front end (and back end) changed a lot. new bumper, fenders, hood, grille, headlights, foglights
and rear trunk and taillights are different as well
Marn1
03-22-19 10:16 AM
ArmyofOne
07-21-17 08:19 PM
sobehemi
05-01-09 04:24 AM
