How to replace A/C filter?
Hello,
Whenever I start the car, it says the A/C filter needs replacing. Is it something DIY job or require dealer? Please let me know where to get it, and how to replace it possible. Thanks much.
SL
SL
Hello,
The a/c filter is very easy to replace and your local auto part store should have an after market filter avaible. The filter is accessable through the glove compartment remove the black cover in the back and the filter will slide out . (You will need a flash light to look in the back of the glove compartment) To reset the filter reminder you can refer to the owners manual.
Good luck Mike
Good luck Mike
