How to override Nav on 02 LS430
No, this is *not* to ask how to do this, it's about HOW to do this.
On Gen3 Nav systems (01/02/03), go to:
Options -> DVD ->
On the DVD info screen,
Touch upper left of screen
Touch lower left of screen
Then touch lower RIGHT of screen.
Diagnostic screen will appear, then press and HOLD the Override button
for approximately 5 seconds. T
Then select BACK.
Unfortunately, it'll only keep this setting until the car is turned off so you'll need to do this each time you start the car.
But the good news is that you can do this while you're moving so you don't have to stop and pull over to override the settings.
Just thought I'd pass that on.
-aki
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Options -> DVD ->
Then select BACK.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
-aki
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
there is another one:
while moving :
information
Languge
you will have the same screen you have when you start the car then
Then select BACK.
And then the same like above
another Q can i chang the reciver from 3Gen to 4Gen i have 2002 LS430 and i want the same NAVI systen that they have on 04+
thank you
while moving :
information
Languge
Then select BACK.
thank you
LuckyGX
GX - 1st Gen (2003-2009)
01-28-07 04:16 PM
