Help with removing radio?
I am trying to get to the radio on an 05 LS430 to install a VAISTECH ipod adapter and get help on doing this from other threads.
I am stuck at one point. I have removed the bezel that contains the seat A/C controls and now trying to remove the panel that contains the slideout drawer and CD changer lid. I found a Phillips screw on each side and also one screw dead center for this trim piece. I removed all 3 screws and tried to pull out this panel. It moves a little bit but feels like something is still holding it in. I have tried moderate force and it won't come out. I don't see any other screws below this trim panel.
What am I missing? Another screw, or does it take a lot of force to pull this trim panel out?
Thanks for any help
Thanks for any help
The only bolts or screws will be UNDER that piece. I thought there were only 2 phillips screws holding it on at the bottom, and I'm pretty sure that's the case.
You may just need to tug harder. Try that!
Shawn
Shawn
