Adjusted air suspension ride height
Old 03-28-07, 01:06 PM
  #31
FLIPPU
FLIPPU's Avatar
I used this method AND also the DataSystem..I do not think it makes a difference in ride height as I am only able to lower it to "5" on the controller, where my 01 UL allowed me to go all the way down to "9" i think it was.
Mike
Old 03-28-07, 02:58 PM
  #32
juniorEXE
juniorEXE's Avatar
Mike
Hey Mike are you sure your controller isnt in safe mode?
Old 03-28-07, 09:23 PM
  #33
FLIPPU
FLIPPU's Avatar
I dunno..didn't know such a thing existed on this controller.
Old 03-28-07, 09:37 PM
  #34
juniorEXE
juniorEXE's Avatar
These are tips I got from Dominik over on VSC. Have fun with it!
p.s. you better post updated pics
Originally Posted by Dominik
Well, first off you should verify that the unit is not in "safety mode"...
While the unit is off , press the select Switch (Bottom left switch with the square picture on it). While continuing to press the button, turn the ighition key to ON. When the unit turns on you will see "ホアンキジュンMODE" or something like that on the screen.
Press the UP switch on the right side of the unit, and the unit will display "EXTRA-DOWN MODE" When this is being displayed, press the Select switch to save the setting.
Now that you have confirmed the extra down mode, you can try a couple of things for getting it into "Hyper Low" mode as described on the website. I couldnt find any instructions for this, but for all the other controllers i have used, SuperLow is achieved by setting it to the lowest setting (i.e. 9), and then holding the down button for about 5 seconds - the display should change as per the image on the website. Do the same for front and back...
Also, getting it out of hyperlow usually requires setting the controller to at least 5. Something about resetting the computer
Hope that helps
Old 03-28-07, 09:46 PM
  #35
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I lowered the drivers side, and its still sitting up so high... not sure why its doing that. Anyone run into that problem?
Old 03-29-07, 10:32 AM
  #36
FLIPPU
FLIPPU's Avatar
The car actually tries to EVEN the height depending on how the ground is..It's like AUTOLEVEL. You must adjust all the manual settings (rods, sliders) to where you want it first, then you will see the difference in height.
Mike
Old 03-30-07, 12:53 PM
  #37
Nauticalx
Nauticalx's Avatar
huh? aside from the sensors which we are adjusting, the air suspension doesnt have any other idea how its sitting. those sensors tell it where it is.
grandls4- maybe ur sensor is reading incorrectly? or maybe you turned them more than 360 because they will go all the way around in circles. i dont know it that would throw them off or not.
Old 03-31-07, 08:45 PM
  #38
Dr. Jekyll
Dr. Jekyll's Avatar
Mike
This seems to be the case with my system too. I believe the 01-03's go to 9 and the 04+ goes as low as 5. My unit does not seem to be in safe mode and i cannot access the super low mode it advertises.
Old 04-21-07, 12:01 PM
  #39
bb430
bb430's Avatar
Today, I tried to lower my "SUV" ride height down to "normal" height but all it lowerd was about 1/2" at the front. The key word in this adjustment is "with the car started" so that you can feel the car lowering itself. I had reached the limite of the rods and are thinking about taking them off and saw off each ends to make them shorter. Any thoughts?
I would like to have a ride height of 27" from ground to the fender(front). I know this is not the way to measure them but it's the easier way.
Old 04-21-07, 12:38 PM
  #40
jpcdmd
jpcdmd's Avatar
or maybe just have two rods made from the appropriate sized steel, have the ends threaded, and just swap them out with the stock ones. A machine shop could probably do that in 5 mins. If you do it post the specs so others can do it. I was thinking about doing it but can't find the time.
Old 04-30-07, 03:42 PM
  #41
vraa
CL Folding Team Starter
vraa's Avatar
I guess I'm an idiot or something.
I just tried to do this, I located both of the front rods.
On the driver side front, I was able to take out the rod but only adjust the top nut, the bottom nut seemed locked into it's position.
I gave up on the rest because of that...
I guess the 600$ Datasystem is for me?
If it's any help though, the LX470 has the same front rods when I peaked under it.
Old 05-03-07, 10:28 PM
  #42
firasm
firasm's Avatar
Will this height mod work on a 95 LS400? do they have the same components, coz im looking into buying one.
thanks
Old 05-03-07, 10:41 PM
  #43
FLIPPU
FLIPPU's Avatar
thanks
If your car came with AIR SUSPENSION, it will probably be similar.
Mike
Old 05-03-07, 10:49 PM
  #44
firasm
firasm's Avatar
thanks Mike
Old 05-12-07, 02:09 PM
  #45
Topshottaz
Topshottaz's Avatar
Is This Too Low?
Quick Reply: Adjusted air suspension ride height
