LS430 Service Question
05-02-07, 10:56 AM
my 04' LS had a Red Triangle with ! mark inside... what does that mean?
05-02-07, 02:05 PM
it could mean anything really...like the sunroof is open, trunk is open...key not detected...etc......
05-03-07, 03:24 AM
CL Folding Team Starter
It should say what is causing it. Perhaps you need maint.?
05-03-07, 05:20 AM
In my case, it's a "too sensitive" emergency brake detector - even if I just brush it with my foot - it thinks it's on - and I get the triangle with the exclamation mark. So I would check everything.
05-03-07, 12:20 PM
thanks everyone, it was just the low tire pressure... but I reset it, and it's coming back on after a few minutes later...
05-03-07, 12:24 PM
If you look, the display will tell you what's wrong. My cabin filter needed to be replaced and I got the same message. You will have to look fast to read the message on the display.
Craig
05-03-07, 01:15 PM
Forum Administrator
Mine just came on today and said (quickly) "maintenance soon" or something like that
05-03-07, 02:04 PM
idle question
Different question, what RPM does you car idle at start up, my is above 1000 rpm... is this normal?
05-25-07, 07:02 AM
not at all mine idles below 500
05-25-07, 01:07 PM
when you just started up the car, it will hover around 1000rpm, but it will soon drop to below...and stay around the 500rpm mark .
05-29-07, 09:02 AM
my car is doing the same now, it just wasn't driven in awhile...
my3uzfe
05-14-17 02:08 PM
askiba
08-01-11 08:43 PM
blue99GS4
09-20-10 12:22 PM
Datacom9
08-27-07 07:31 PM
pvo
03-11-04 06:37 PM
2002 ,
2006 ,
430 ,
detected ,
explanation ,
key ,
lexus ,
ls ,
ls430 ,
ls430key ,
point ,
reset ,
service ,
triangle
