Does anybody know how to rewire fog lights???
Old 05-24-07, 03:04 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
Originally Posted by WEBINTL
It's kind of hard for me to go into full detail, i'll have to pull out the fuse box again to give yall the exact color wires. But i went into the fuse box by the driver side headlight and found the foglamp fuse, i cut the wire that feeds the foglamps and spliced it into the park lamp wires. each foglamp has a different wire. I still didn't figure out how to do this and still be able to work the foglights with the inside switch. With this method once you turn on the park lights the fogs remain on, the switch will not work. I'll soon figure it out..
I did a write up about this when I did my LS400 (in the LS400 forum). I also did on my GS430. The key to keeping the operation of your switch is to wire from the switch to the relay, and then I connected it to my parking light switch. So that BOTH need to be on for the fogs to operate.
Old 05-24-07, 06:20 PM
WEBINTL
WEBINTL's Avatar
On the ls430 i cant find the wire that goes from the switch to the relay. i dont know how they have it wired but with the test light theres no wire with signal.
Old 05-25-07, 01:54 AM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I wired one myself. Its much easier that way, takes about 20mins.
Old 05-25-07, 06:15 AM
WEBINTL
WEBINTL's Avatar
i do have another question also.. how can i turn off the daytime running lights.
Old 05-26-07, 12:40 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
I havent seen anyone do it here, but check the GS forum... they have seemed to figured out a way.
Old 07-15-12, 03:34 AM
kingblack
kingblack's Avatar
i wanted to do the same to my 99 sc. do anyone know the how? how to re-wire the fogs to park lights and still switch operation on the sc? btw sorry for thread jacking.
aceboogie6
GS - 1st Gen (1993-1997)
05-06-11 07:51 PM
khutch
SC- 1st Gen (1992-2000)
11-10-09 01:17 AM
Baybarea
39
07-03-07 05:45 PM
powders2k
04-25-06 10:49 PM
kamtra
Lighting
07-18-04 08:48 PM
Quick Reply: Does anybody know how to rewire fog lights???
