ASC Data Air Ride Controller
Old 07-03-07, 08:33 PM
junjdm
junjdm's Avatar
Originally Posted by airtime
Any step by step instructions?
On the step by step instructions is self explanatory, once you have it on the correct car! If you have the actual unit and have any questions I can try to help as much as possible.
Old 07-03-07, 08:38 PM
junjdm
junjdm's Avatar
Originally Posted by Dx3
How much is it? How do you install?
Jonny
The price is $720 and I believe that is w/ the harness, on some websites, I found mine here on clublexus, and got mine brand new for $475. I can say I got a pretty nice deal on it.
On the install, they have instructions that come w/ it. Basically you have to remove the bottom glove compartment which is 4 bolts, then remove the woodgrain and the air vent connected to it. In the air vent there are 2 clips you have to pop out of place before removing the woodgrain. Onces that is off, its really simple plug and play! It took me about 30-40mins being very careful.
I will post pics soon, it has been raining a lot over here so haven't got a chance to wash my car! So when I do, pics will definetly being going up!
Old 07-08-07, 06:00 PM
KINGLS430
KINGLS430's Avatar
Would u recomend getting it profesionally installed? and if so is it possible to get it mounted in an easy to reach place? i bought one and it is on the way. But it does not sound like somthing i should do....
Old 07-08-07, 08:36 PM
airtime
airtime's Avatar
KingLS430, where did you get yours from? and cost? I'm in the mist of debating using the controller or just manually adjust the sensors.
Old 07-09-07, 12:17 AM
KINGLS430
KINGLS430's Avatar
i got it from l tuned Parts thier a bit pricey $720 but if it does what evreyone says it does then it has to be better than doing i manually i would definetly screw somthing up if i did it manually
Old 07-09-07, 09:31 AM
junjdm
junjdm's Avatar
The install was easy to me. I really think you could do it, let me know when you get it and I can pretty much walk you through it. And yes it is all worth it, way better than doin it manually. And the extra down mode is a WOW! I should be posting pictures up soon, it has been raining like crazy here. But pics will go up soon on a new thread.
Old 07-09-07, 01:53 PM
FLIPPU
FLIPPU's Avatar
Also, Installation is DIFFERENT for 01-03 and 04+ because of AIR SUSPENSION computer location.
Mike
Old 07-09-07, 02:32 PM
airtime
airtime's Avatar
Mike
Mike, where's the location for 04+ ??
Thanks.
Old 07-10-07, 10:17 AM
KINGLS430
KINGLS430's Avatar
Mike i have an 06 model where is the air suspension computer in my car?
Old 07-11-07, 09:56 AM
FLIPPU
FLIPPU's Avatar
the 04+ will be UNDER the steering wheel column...it's not very easy to plug stuff in there, but it is doable...BUT there is still 1 wire that needs to be extended and plugged in a harness that is STILL behind the glove box.
So either way, you will need to remove the glove box and some soldering or butt connecting a wire to extend it all the way to the other side of the dash.
Mike
Old 07-15-07, 12:28 PM
JDMPalace
JDMPalace's Avatar
Mike, do you have more info about the wire color and location
Old 07-16-07, 08:24 AM
FLIPPU
FLIPPU's Avatar
wire color on the DataSystem connector is black and it comes with a BLUE plug which get's plugged into a BLUE OEM Plug behind the glove box.
Mike
Old 07-18-07, 02:45 AM
JDMPalace
JDMPalace's Avatar
Thank you sir !!
Old 07-21-07, 06:37 AM
{-.-}'s Avatar
Mike you guys should do a write up and for those with diffrent cars also.
GREAT to see more and more of you all enjoying the Air Sus controller.
COOL BEANS
JSTALEX
08-30-14 01:00 AM
airtime
05-12-10 12:43 AM
cuong21
07-14-08 01:20 PM
nosyajg
07-11-06 05:02 AM
1coolexrx
02-24-06 10:17 AM
Quick Reply: ASC Data Air Ride Controller
