Subwoofer rattleing
technically...yes....i could wire them in series and run both at the same time...wiring them in parallel would be too low ohms for the amp
but both of them in series would wouldnt sound as good as the one in the box/trunk by itself getting the full power...so I do either or, but not both...i'm also not sure how it would sound with bass coming from two different speakers at two different angles (acoustics)...might have some cancelling out goin on...i'll try it today and see how it sounds
I wouldn't try it. It probably could push it but not sound very good. Plus you run the risk of blowing the factory amp and that runs around $1000 to replace.
I am about to get a seperate sub (8" or 10") installed in the stock hole and run a seperate amp to it. That way I don't have to worry about the factory amp blowing and I will get a lot more bass.
Tantrix
08-31-16 06:20 AM
